[GRASS-dev] [grass-code I][359] GRASS fails to build with make -j3
grass-codei at wald.intevation.org
Thu Apr 5 06:01:55 EDT 2007
code I item #359, was opened at 2007-04-05 12:01
Status: Open
Priority: 4
Submitted By: Maciej Sieczka (msieczka)
Assigned to: Nobody (None)
Summary: GRASS fails to build with make -j3
Issue type: other bug
Issue status: None
GRASS version: CVS HEAD
GRASS component: build
Operating system: all
Operating system version:
GRASS CVS checkout date, if applies (YYMMDD): 050407
Initial Comment:
On multi cpu machines it is possible to speed up compilation time greatly using the -j switch with make (eg. -j3 for 2 cpus).
make -j3 works fine on my dual core Intel with all the software I'm building from source (including eg. PROJ, GEOS, HDF4, POSTGIS, GDAL, QT4).
But when I build GRASS with make -j3, plenty of errors crop out after "Waiting for unfinished jobs...." information. In a result, no single GRASS module is build properly. However, GRASS builds fine on the same machine if -j3 is not used.
configure and make logs attached.
Maciek
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=359&group_id=21
