[GRASS-dev] [grass-code I][359] GRASS fails to build with make -j3
Glynn Clements
glynn at gclements.plus.com
Thu Apr 5 09:05:53 EDT 2007
grass-codei at wald.intevation.org wrote:
> code I item #359, was opened at 2007-04-05 12:01
> Status: Open
> Priority: 4
> Submitted By: Maciej Sieczka (msieczka)
> Assigned to: Nobody (None)
> Summary: GRASS fails to build with make -j3
> Issue type: other bug
> Issue status: None
> GRASS version: CVS HEAD
> GRASS component: build
> Operating system: all
> Operating system version:
> GRASS CVS checkout date, if applies (YYMMDD): 050407
> Initial Comment:
> On multi cpu machines it is possible to speed up compilation time
> greatly using the -j switch with make (eg. -j3 for 2 cpus).
> make -j3 works fine on my dual core Intel with all the software I'm
> building from source (including eg. PROJ, GEOS, HDF4, POSTGIS, GDAL,
> QT4).
> But when I build GRASS with make -j3, plenty of errors crop out
> after "Waiting for unfinished jobs...." information. In a result, no
> single GRASS module is build properly. However, GRASS builds fine on
> the same machine if -j3 is not used.
> configure and make logs attached.
The first thing I notice is that the first error is usually a missing
header file, e.g.:
copy.c:7:28: error: grass/datetime.h: No such file or directory
adj_cellhd.c:14:23: error: grass/gis.h: No such file or directory
This is due to the "headers" target in the "libs" directory being run
in parallel with other jobs.
This specific issue can probably be solved by changing lib/Makefile
default: headers subdirs
to:
default: subdirs
subdirs: headers
This should prevent the subdirs target from being run before the
headers target has completed.
However: I'm not sure whether parallel make will actually be useful
with the existing Makefiles, due to the use of a shell "for" loop for
building subdirectories:
subdirs:
@list='$(SUBDIRS)'; \
for subdir in $$list; do \
echo $$subdir ; \
$(MAKE) -C $$subdir || echo $(CURDIR)/$$subdir >> $(GRASS_HOME)/error.log; \
done
[From include/Make/Dir.make]
To have the subdirectories built in parallel, you would need to use
something like:
.PHONY: subdirs $(SUBDIRS)
subdirs: $(SUBDIRS)
$(SUBDIRS):
$(MAKE) -C $@
