[GRASS-dev] discussion: replacing ps.map
Fri Apr 6 11:58:24 EDT 2007
William Kyngesburye wrote:
> > This suggests that the linker needs something similar to the
> > -Wl,-rpath-link switch which is used on Linux:
> > 	CC_SEARCH_FLAGS='-Wl,-rpath-link,${LIB_RUNTIME_DIR}'
> > This tells the linker where to look for dependencies.
> > Without that, you will need to ensure that the lib directory of any
> > installed version of GRASS isn't searched automatically (e.g. due to
> > $DYLD_LIBRARY_PATH or similar).
> Hm, in the GRASS way of linking, all libs are linked in directly,
> whether they are indirect or not.  Shouldn't the psdriver lib be
> linked to raster lib then?  Currently grass.make has:
> RASTERLIB     = -l$(RASTER_LIBNAME) $(PNGDRIVERLIB) $(DRIVERLIB) $(GISLIB)
> If I add $(PSDRIVERLIB) to that, it doesn't try to link the installed
> libraries and everything builds successfully.
Currently, we do that to allow for the --disable-shared case; it
shouldn't actually be necessary for shared libraries.
OTOH, RASTERLIB needs $(PSDRIVERLIB) to the same extent that it needs
$(PNGDRIVERLIB), so it should be added so long as we're listing
dependencies explicitly.
Fixed in CVS.
