[GRASS-dev] discussion: replacing ps.map
William Kyngesburye
woklist at kyngchaos.com
Fri Apr 6 12:14:06 EDT 2007
Thanks. GRASS build is happy again.
On Apr 6, 2007, at 10:58 AM, Glynn Clements wrote:
> William Kyngesburye wrote:
>> RASTERLIB = -l$(RASTER_LIBNAME) $(PNGDRIVERLIB) $(DRIVERLIB) $
>> (GISLIB)
>> If I add $(PSDRIVERLIB) to that, it doesn't try to link the installed
>> libraries and everything builds successfully.
> Currently, we do that to allow for the --disable-shared case; it
> shouldn't actually be necessary for shared libraries.
I've wondered about that, so that's the reason for the explicit linking.
> OTOH, RASTERLIB needs $(PSDRIVERLIB) to the same extent that it needs
> $(PNGDRIVERLIB), so it should be added so long as we're listing
> dependencies explicitly.
> Fixed in CVS.
> Glynn Clements <glynn at gclements.plus.com>
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an
illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
