[GRASS-dev] [grass-code P][364] Tiny patch for building
grass-codep at wald.intevation.org
Sat Apr 7 07:09:08 EDT 2007
code P item #364, was opened at 2007-04-07 13:09
Status: Open
Priority: 3
Submitted By: Francesco Lovergine (frankie)
Assigned to: Nobody (None)
Summary: Tiny patch for building
Patch status: None
Patch type: fix
GRASS component: build
GRASS version: 6.2
GRASS CVS checkout date, if applies (YYMMDD):
Initial Comment:
While building for debian, programming manual is generated in a second phase.
In the following case the 3 files are already present and read-only, so build fails.
diff -urNad grass-6.2.2~20070406~/scripts/r.in.wms/Makefile grass-6.2.2~20070406/scripts/r.in.wms/Makefile
--- grass-6.2.2~20070406~/scripts/r.in.wms/Makefile 2007-04-07 12:52:36.000000000 +0200
+++ grass-6.2.2~20070406/scripts/r.in.wms/Makefile 2007-04-07 12:54:38.000000000 +0200
@@ -6,4 +6,4 @@
default: script
$(MKDIR) $(GISBASE)/etc/r.in.wms/
- cp r.in.gdalwarp wms.request wms.download $(GISBASE)/etc/r.in.wms/
+ cp -f r.in.gdalwarp wms.request wms.download $(GISBASE)/etc/r.in.wms/
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=205&aid=364&group_id=21
