[GRASS-dev] [grass-code P][364] Tiny patch for building
Sat Apr 7 07:43:26 EDT 2007
grass-codep at wald.intevation.org wrote:
> Initial Comment:
> While building for debian, programming manual is generated in a second phase.
> In the following case the 3 files are already present and read-only, so build fails.
> diff -urNad grass-6.2.2~20070406~/scripts/r.in.wms/Makefile grass-6.2.2~20070406/scripts/r.in.wms/Makefile
> --- grass-6.2.2~20070406~/scripts/r.in.wms/Makefile     2007-04-07 12:52:36.000000000 +0200
> +++ grass-6.2.2~20070406/scripts/r.in.wms/Makefile      2007-04-07 12:54:38.000000000 +0200
> @@ -6,4 +6,4 @@
>  default: script
>         $(MKDIR) $(GISBASE)/etc/r.in.wms/
> -       cp r.in.gdalwarp wms.request wms.download $(GISBASE)/etc/r.in.wms/
> +       cp -f r.in.gdalwarp wms.request wms.download $(GISBASE)/etc/r.in.wms/
This should use $(INSTALL) instead of "cp", e.g.
	for file in r.in.gdalwarp wms.request wms.download ; do $(INSTALL) $$file ; done
