[GRASS-dev] [grass-code P][364] Tiny patch for building
Glynn Clements
glynn at gclements.plus.com
Sat Apr 7 09:27:56 EDT 2007
Markus Neteler wrote:
> > > Initial Comment:
> > > While building for debian, programming manual is generated in a second phase.
> > > In the following case the 3 files are already present and read-only, so build fails.
> > > diff -urNad grass-6.2.2~20070406~/scripts/r.in.wms/Makefile grass-6.2.2~20070406/scripts/r.in.wms/Makefile
> > > --- grass-6.2.2~20070406~/scripts/r.in.wms/Makefile 2007-04-07 12:52:36.000000000 +0200
> > > +++ grass-6.2.2~20070406/scripts/r.in.wms/Makefile 2007-04-07 12:54:38.000000000 +0200
> > > @@ -6,4 +6,4 @@
> > > default: script
> > > $(MKDIR) $(GISBASE)/etc/r.in.wms/
> > > - cp r.in.gdalwarp wms.request wms.download $(GISBASE)/etc/r.in.wms/
> > > + cp -f r.in.gdalwarp wms.request wms.download $(GISBASE)/etc/r.in.wms/
> > This should use $(INSTALL) instead of "cp", e.g.
> > for file in r.in.gdalwarp wms.request wms.download ; do $(INSTALL) $$file ; done
> Submitted as
> for file in r.in.gdalwarp wms.request wms.download ; do $(INSTALL) -m 755 $$file $(GISBASE)/etc/r.in.wms/ ; done
FWIW, you don't need the "-m 755"; that's the default.
Use $(INSTALL_DATA) for files which shouldn't be made executable.
