[GRASS-dev] return of the OSX xterm question
William Kyngesburye
woklist at kyngchaos.com
Sun Apr 8 19:41:03 EDT 2007
Messing around today, and I recalled the discussion about how to get
grass-xterm-wrapper to use an OSX Terminal. I think I figured out
something that could work. Combining Lorenzo's AppleScript sample
and Glynn's way to strip the command out of the parameters and a
little experimentation, I have a relatively simple script to do this.
Though simple - it's all handled in grass-xterm-wrapper, so there is
no need to rewrite scripts - it's a bit of a messy AppleScript hack.
The main problem I couldn't fix is that the AppleScript command to
run a shell script in the Terminal chokes on large command strings (1
byte over 1K), and a large string is needed to pass the env vars to
the Terminal. So I pass them in byte-sized (hee hee) pieces, and
there is the potential that the user can interrupt this by switching
to another Terminal window.
But it's fast enough that it shouldn't be a serious problem.
To test this, replace lib/init/grass-xterm-wrapper with this one and
rebuild GRASS, or replace the installed grass/etc/grass-xterm-
wrapper. Before running GRASS, set GRASS_XTERM=Terminal.app in your
~/.bash_profile.
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20070408/e864db4e/grass-xterm-wrapper.obj
I tested it in the Tcl GUI startup mapset screen, choosing New
Location by Projection Values.
One thing I'm wondering - is there a way to run a command in a shell
script without displaying the command in the shell? Something like
the @ prefix used in makefiles? Since I have to recreate the env
vars in the new Terminal window, a lot of stuff is spewed to the user
before the requested command is actually run.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an
illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
