[GRASS-dev] return of the OSX xterm question
Sun Apr 8 20:00:12 EDT 2007
William Kyngesburye wrote:
> One thing I'm wondering - is there a way to run a command in a shell
> script without displaying the command in the shell?  Something like
> the @ prefix used in makefiles?  Since I have to recreate the env
> vars in the new Terminal window, a lot of stuff is spewed to the user
> before the requested command is actually run.
This isn't a shell issue; it's an artifact of remote-controlling an
existing terminal through AppleScript.
Can you not just run the command in a separate terminal instance, in
the same way that xterms are used?
