[GRASS-dev] return of the OSX xterm question
William Kyngesburye woklist at kyngchaos.com
Sun Apr 8 20:14:55 EDT 2007
On Apr 8, 2007, at 7:00 PM, Glynn Clements wrote:
> William Kyngesburye wrote:
>> One thing I'm wondering - is there a way to run a command in a shell
>> script without displaying the command in the shell?  Something like
>> the @ prefix used in makefiles?  Since I have to recreate the env
>> vars in the new Terminal window, a lot of stuff is spewed to the user
>> before the requested command is actually run.
> This isn't a shell issue; it's an artifact of remote-controlling an
> existing terminal through AppleScript.
Hmm.  My OSX app startup does this too.  I thought I've seen it
purely from running a shell script in a Terminal, but I could be
mistaken.  Oh well, just have to put up with a little clutter...
> Can you not just run the command in a separate terminal instance, in
> the same way that xterms are used?
Not quite.  Problems (rehash from previous discussion):
- doesn't inherit env
- returns immediately, without waiting for command to finish
- leaves Terminal as active application, so one must manually switch
back to whatever called it (ie X11/Tcltk)
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian]  What are you supposed to do WITH a maniacally depressed
robot?
[Marvin]  You think you have problems?  What are you supposed to do
if you ARE a maniacally depressed robot?  No, don't try and answer,
I'm 50,000 times more intelligent than you and even I don't know the
answer...
- HitchHiker's Guide to the Galaxy
