[GRASS-dev] return of the OSX xterm question
Glynn Clements
glynn at gclements.plus.com
Mon Apr 9 11:18:41 EDT 2007
William Kyngesburye wrote:
> > Also, isn't there anything like xterm which uses the native GUI? Or is
> > there something about the nature of the GUI which makes that
> > impossible?
> I saw an alternative recently, and it claims xterm compatibility.
> It's in beta right now. One small problem is requiring/suggesting
> yet another extra on a user's system.
> But mainly, I can't understand how the xterm compatibility part would
> work: to be able to handle the xterm flags, it has to be able to run
> from the CLI, but when run from the CLI an application executable
> opens a completely new instance of the whole application, not a new
> window (exactly the same problem as the browser issue I'm working on).
And what's the problem with that?
I can see why this might be a problem for a browser; I don't see why
it's a problem for a terminal.
