[GRASS-dev] return of the OSX xterm question
Glynn Clements
glynn at gclements.plus.com
Mon Apr 9 13:53:18 EDT 2007
William Kyngesburye wrote:
> >> But mainly, I can't understand how the xterm compatibility part would
> >> work: to be able to handle the xterm flags, it has to be able to run
> >> from the CLI, but when run from the CLI an application executable
> >> opens a completely new instance of the whole application, not a new
> >> window (exactly the same problem as the browser issue I'm working
> >> on).
> > And what's the problem with that?
> > I can see why this might be a problem for a browser; I don't see why
> > it's a problem for a terminal.
> It's a general OSX problem/quirk when running any .app application
> from the CLI. If the application is already running, you don't get a
> new window in the application (or whatever the default action is,
> depending on what is passed to it). New instances of whole
> applications is not the way to run OSX apps.
> Instead, you must tell the system to open a file with a particular
> application (the 'open' CLI command) so the system can take care of
> deciding whether the application is already running.
That doesn't address my point.
What is the problem with having each terminal window belong to a
separate process? Or, from a different perspective, what is the
advantage to having a single process manage multiple terminal windows?
I can see some advantages for a browser, but not for a terminal.
