[GRASS-dev] Re: errors in: messages - fixed
Martin Wegmann
wegmann at biozentrum.uni-wuerzburg.de
Thu Apr 12 04:12:23 EDT 2007
> > > > I get various "errors in:" messages after an update. So far I did not
> > > > find similar threats on the mailing lists.
> > > > After a cvs update, make distclean - configure - make, a long list of
> > > > "errors in:" is prompted (see below).
> > > > I deleted my old cvs folder and removed the grass files in /usr/local
> > > > and did a fresh cvs but still the same error appears.
> > > > It is a temporal problem or did I forget something?
> > > > Using debian testing.
> > > > TIA Martin
> > > > Errors in:
> > > > ...//grass/grass6/lib/proj
> > > --snip--
> > > > (In case of errors please change into the directory with error and
> > > > run 'make')
> > > please do that, starting with lib/proj
> > baliola at wpf063:~/software/grass/grass6$ cd lib/proj/
> > baliola at wpf063:~/software/grass/grass6/lib/proj$ make
> gcc -shared -o
> /home/baliola/software/grass/grass6/dist.i686-pc-linux-gnu/lib/libgrass_gpr
>oj.6.3.cvs.so
> -L/home/baliola/software/grass/grass6/dist.i686-pc-linux-gnu/lib
> -Wl,--export-dynamic
> -Wl,-rpath-link,/home/baliola/software/grass/grass6/dist.i686-pc-linux-gnu/
>lib
> > OBJ.i686-pc-linux-gnu/get_proj.o OBJ.i686-pc-linux-gnu/do_proj.o
> > OBJ.i686-pc-linux-gnu/convert.o OBJ.i686-pc-linux-gnu/datum.o
> OBJ.i686-pc-linux-gnu/ellipse.o -lgrass_gis -lgrass_datetime -lz -lproj
> -L/usr/local/lib -lgdal -lodbc -lodbcinst -ljasper -lmfhdf -ldf -lgif
> -ljpeg -ltiff -lpng -lnetcdf -lcfitsio -L/usr/local/grass-6.3.cvs//lib
> -lgrass_vect -lgrass_dig2 -lgrass_dgl -lgrass_rtree -lgrass_linkm
> -lgrass_dbmiclient -lgrass_dbmibase -lgrass_I -lgrass_gproj -lgrass_vask
> -lgrass_gmath -lgrass_gis -lgrass_datetime -lpq -L/usr/lib -lpq -lz -lm
> -lrt -ldl
> > (cd
> > /home/baliola/software/grass/grass6/dist.i686-pc-linux-gnu/lib; ln -f -s
> libgrass_gproj.6.3.cvs.so
>oj.so)
> > /usr/bin/ld: cannot find -lgrass_vect
> As libgrass_gproj library doesn't use libgrass_vect, this is almost
> certainly a GDAL issue (i.e. your GDAL library was built with GRASS
> support, but you've removed the GRASS installation on which it
> depends). If that is the case, you will first need to re-install GDAL;
> if you're building it from source, you'll need to build without GRASS
> support.
I removed my whole gdal installation (deb and source) and compiled the source
without GRASS support and pointed GRASS to this GDAL path.
Now it works fine again. Thanks!
Martin
