[GRASS-dev] ascii export and import, large file problem
Fri Apr 13 14:02:16 EDT 2007
Jerry Nelson wrote:
> An update on ascii export and import. When we set decimals to 16 in the
> export and import commands, the difference worked as expected; that is,
> there is no difference between the original and the exported/imported/ new
> version. Is this something that needs to be put in the documentation? Jerry
You're omitting something important: the details of the projection
step.
r.proj projects into an existing region; it doesn't create it itself.
Something created that region, and that's where everything went wrong.
Beyond that, if you export an ArcGrid file from a region with
non-square pixels, then re-import that file, the result will be wrong
however many decimal places you use.
