[GRASS-dev] Unused files
Glynn Clements
glynn at gclements.plus.com
Mon Apr 16 13:03:12 EDT 2007
There are currently 78 source files whose functions don't appear to be
used by anything.
Some of these may be used by components which aren't being compiled on
my system, and some have been added with the intention of future use.
OTOH, some of them may simply be obsolete.
Please provide comments as to whether specific files should or
shouldn't be removed.
The complete list is:
lib/cdhc/enormp.c | enormp
lib/cdhc/shapiro2.c | shapiro_francia
lib/cdhc/shapiroe.c | shapiro_wilk_exp
lib/cdhc/cvmw2e.c | cramer_von_mises_exp
lib/cdhc/kse.c | kolmogorov_smirnov_exp
lib/cdhc/kuiprsve.c | kuipers_v_exp
lib/cdhc/watsonue.c | watson_u2_exp
lib/cdhc/andrsnde.c | anderson_darling_exp
lib/cdhc/chisqe.c | chi_square_exp
lib/datetime/same.c | datetime_is_same
lib/datetime/local.c | datetime_get_local_time
lib/datetime/local.c | datetime_get_local_timezone
lib/db/sqlp/print.c | sqpPrintStmt
lib/db/dbmi_base/dirent.c | db_alloc_dirent_array
lib/db/dbmi_base/dirent.c | db_dirent
lib/db/dbmi_base/dirent.c | db_free_dirent_array
lib/db/dbmi_base/legal_dbname.c | db_legal_tablename
lib/db/dbmi_base/strip.c | db_strip
lib/db/dbmi_base/whoami.c | db_whoami
lib/db/dbmi_base/xdrfloat.c | db__recv_float
lib/db/dbmi_base/xdrfloat.c | db__recv_float_array
lib/db/dbmi_base/xdrfloat.c | db__send_float
lib/db/dbmi_base/xdrfloat.c | db__send_float_array
lib/db/dbmi_client/c_add_col.c | db_add_column
lib/db/dbmi_client/c_bindupdate.c | db_bind_update
lib/db/dbmi_client/c_createdb.c | db_create_database
lib/db/dbmi_client/c_delete.c | db_delete
lib/db/dbmi_client/c_deletedb.c | db_delete_database
lib/db/dbmi_client/c_drop_col.c | db_drop_column
lib/db/dbmi_client/c_drop_index.c | db_drop_index
lib/db/dbmi_client/c_drop_tab.c | db_drop_table
lib/db/dbmi_client/c_finddb.c | db_find_database
lib/db/dbmi_client/c_insert.c | db_insert
lib/db/dbmi_client/c_list_idx.c | db_list_indexes
lib/db/dbmi_client/c_listdb.c | db_list_databases
lib/db/dbmi_client/c_openinsert.c | db_open_insert_cursor
lib/db/dbmi_client/c_openupdate.c | db_open_update_cursor
lib/db/dbmi_client/c_update.c | db_update
lib/db/dbmi_client/c_version.c | db_gversion
lib/db/dbmi_client/printtab.c | db_print_column_definition
lib/db/dbmi_client/printtab.c | db_print_table_definition
lib/db/dbmi_driver/d_mkdir.c | db_driver_mkdir
lib/display/clip.c | D_clip
lib/display/scan_dbl.c | D_scan_double
lib/display/scan_float.c | D_scan_float
lib/display/scan_int.c | D_scan_int
lib/external/shapelib/shpopen.c | SHPClose
lib/external/shapelib/shpopen.c | SHPComputeExtents
lib/external/shapelib/shpopen.c | SHPCreate
lib/external/shapelib/shpopen.c | SHPCreateObject
lib/external/shapelib/shpopen.c | SHPCreateSimpleObject
lib/external/shapelib/shpopen.c | SHPDestroyObject
lib/external/shapelib/shpopen.c | SHPGetInfo
lib/external/shapelib/shpopen.c | SHPOpen
lib/external/shapelib/shpopen.c | SHPPartTypeName
lib/external/shapelib/shpopen.c | SHPReadObject
lib/external/shapelib/shpopen.c | SHPRewindObject
lib/external/shapelib/shpopen.c | SHPTypeName
lib/external/shapelib/shpopen.c | SHPWriteHeader
lib/external/shapelib/shpopen.c | SHPWriteObject
lib/g3d/changeprecision.c | G3d_changePrecision
lib/g3d/changetype.c | G3d_changeType
lib/g3d/filecompare.c | G3d_compareFiles
lib/g3d/g3ddoubleio.c | G3d_readDoubles
lib/g3d/g3ddoubleio.c | G3d_writeDoubles
lib/g3d/g3dvolume.c | G3d_getAllignedVolume
lib/g3d/g3dvolume.c | G3d_getVolume
lib/g3d/g3dvolume.c | G3d_getVolumeA
lib/g3d/g3dvolume.c | G3d_makeAllignedVolumeFile
lib/g3d/retile.c | G3d_retile
lib/g3d/writeascii.c | G3d_writeAscii
lib/gis/clicker.c | G_clicker
lib/gis/dig_title.c | G_get_dig_title
lib/gis/gishelp.c | G_gishelp
lib/gis/histo_eq.c | G_histogram_eq
lib/gis/is.c | G_is_gisbase
lib/gis/is.c | G_is_location
lib/gis/is.c | G_is_mapset
lib/gis/line_dist.c | G_distance2_point_to_line
lib/gis/line_dist.c | G_set_distance_to_line_tolerance
lib/gis/pole_in_poly.c | G_pole_in_polygon
lib/gis/radii.c | G_meridional_radius_of_curvature
lib/gis/radii.c | G_radius_of_conformal_tangent_sphere
lib/gis/radii.c | G_transverse_radius_of_curvature
lib/gis/user_config.c | G_rc_path
lib/gis/version.c | G_version
lib/gmath/la.c | G__matrix_add
lib/gmath/la.c | G_matrix_LU_solve
lib/gmath/la.c | G_matrix_add
lib/gmath/la.c | G_matrix_copy
lib/gmath/la.c | G_matrix_eigen_sort
lib/gmath/la.c | G_matrix_free
lib/gmath/la.c | G_matrix_get_element
lib/gmath/la.c | G_matrix_init
lib/gmath/la.c | G_matrix_inverse
lib/gmath/la.c | G_matrix_print
lib/gmath/la.c | G_matrix_product
lib/gmath/la.c | G_matrix_read
lib/gmath/la.c | G_matrix_scale
lib/gmath/la.c | G_matrix_set
lib/gmath/la.c | G_matrix_set_element
lib/gmath/la.c | G_matrix_stdin
lib/gmath/la.c | G_matrix_subtract
lib/gmath/la.c | G_matrix_transpose
lib/gmath/la.c | G_matrix_zero
lib/gmath/la.c | G_matvect_extract_vector
lib/gmath/la.c | G_matvect_get_column
lib/gmath/la.c | G_matvect_get_row
lib/gmath/la.c | G_matvect_retrieve_matrix
lib/gmath/la.c | G_vector_copy
lib/gmath/la.c | G_vector_free
lib/gmath/la.c | G_vector_init
lib/gmath/la.c | G_vector_norm1
lib/gmath/la.c | G_vector_norm_euclid
lib/gmath/la.c | G_vector_norm_maxval
lib/gmath/la.c | G_vector_set
lib/gmath/la.c | G_vector_sub
lib/gmath/svd.c | G_svbksb
lib/gmath/svd.c | G_svdcmp
lib/gmath/svd.c | G_svelim
lib/imagery/add_cov.c | I_add_covariances
lib/imagery/advance.c | I_tape_advance
lib/imagery/ask.c | I_ask
lib/imagery/ask_subgrp.c | I_ask_subgroup_new
lib/imagery/ask_subgrp.c | I_ask_subgroup_old
lib/imagery/band_io.c | I_close_band
lib/imagery/band_io.c | I_open_band_new
lib/imagery/colors.c | I_free_group_colors
lib/imagery/colors.c | I_read_group_blu_colors
lib/imagery/colors.c | I_read_group_colors
lib/imagery/colors.c | I_read_group_grn_colors
lib/imagery/colors.c | I_read_group_red_colors
lib/imagery/colors.c | I_write_group_blu_colors
lib/imagery/colors.c | I_write_group_colors
lib/imagery/colors.c | I_write_group_grn_colors
lib/imagery/colors.c | I_write_group_red_colors
lib/imagery/image.c | I_close_image
lib/imagery/image.c | I_get_image_row
lib/imagery/image.c | I_image_colors
lib/imagery/image.c | I_open_image
lib/imagery/image.c | I_translate_image_data
lib/imagery/open.c | I_open_group_file_new
lib/imagery/open.c | I_open_group_file_old
lib/imagery/percent.c | I_percent
lib/imagery/proj.c | I_must_be_imagery_projection
lib/imagery/sig2cats.c | I_signature_to_cats
lib/rowio/forget.c | rowio_forget
lib/rst/interp_float/distance.c | IL_dist_square
lib/vector/Vlib/dbcolumns.c | Vect_get_column_names
lib/vector/Vlib/dbcolumns.c | Vect_get_column_names_types
lib/vector/Vlib/dbcolumns.c | Vect_get_column_types
lib/vector/Vlib/graph.c | Vect_graph_add_edge
lib/vector/Vlib/graph.c | Vect_graph_build
lib/vector/Vlib/graph.c | Vect_graph_init
lib/vector/Vlib/graph.c | Vect_graph_set_node_costs
lib/vector/Vlib/graph.c | Vect_graph_shortest_path
lib/vector/Vlib/overlap.c | V__map_overlap
lib/vector/Vlib/overlay.c | Vect_overlay
lib/vector/Vlib/overlay.c | Vect_overlay_and
lib/vector/Vlib/overlay.c | Vect_overlay_str_to_operator
lib/vector/dglib/avl.c | avl_allocator_default
lib/vector/dglib/avl.c | avl_assert_delete
lib/vector/dglib/avl.c | avl_assert_insert
lib/vector/dglib/avl.c | avl_copy
lib/vector/dglib/avl.c | avl_create
lib/vector/dglib/avl.c | avl_delete
lib/vector/dglib/avl.c | avl_destroy
lib/vector/dglib/avl.c | avl_find
lib/vector/dglib/avl.c | avl_free
lib/vector/dglib/avl.c | avl_insert
lib/vector/dglib/avl.c | avl_malloc
lib/vector/dglib/avl.c | avl_probe
lib/vector/dglib/avl.c | avl_replace
lib/vector/dglib/avl.c | avl_t_copy
lib/vector/dglib/avl.c | avl_t_cur
lib/vector/dglib/avl.c | avl_t_find
lib/vector/dglib/avl.c | avl_t_first
lib/vector/dglib/avl.c | avl_t_init
lib/vector/dglib/avl.c | avl_t_insert
lib/vector/dglib/avl.c | avl_t_last
lib/vector/dglib/avl.c | avl_t_next
lib/vector/dglib/avl.c | avl_t_prev
lib/vector/dglib/avl.c | avl_t_replace
lib/gpde/N_solute_transport.c | N_alloc_solute_transport_data2d
lib/gpde/N_solute_transport.c | N_alloc_solute_transport_data3d
lib/gpde/N_solute_transport.c | N_callback_solute_transport_2d
lib/gpde/N_solute_transport.c | N_callback_solute_transport_3d
lib/gpde/N_solute_transport.c | N_free_solute_transport_data2d
lib/gpde/N_solute_transport.c | N_free_solute_transport_data3d
