[GRASS-dev] Unused files
Glynn Clements
glynn at gclements.plus.com
Mon Apr 16 16:14:34 EDT 2007
Daniel Calvelo wrote:
> > lib/db/dbmi_client/c_add_col.c | db_add_column
> > lib/db/dbmi_client/c_bindupdate.c | db_bind_update
> > lib/db/dbmi_client/c_createdb.c | db_create_database
> > lib/db/dbmi_client/c_delete.c | db_delete
> > lib/db/dbmi_client/c_deletedb.c | db_delete_database
> > lib/db/dbmi_client/c_drop_col.c | db_drop_column
> > lib/db/dbmi_client/c_drop_index.c | db_drop_index
> > lib/db/dbmi_client/c_drop_tab.c | db_drop_table
> > lib/db/dbmi_client/c_finddb.c | db_find_database
> > lib/db/dbmi_client/c_insert.c | db_insert
> > lib/db/dbmi_client/c_list_idx.c | db_list_indexes
> > lib/db/dbmi_client/c_listdb.c | db_list_databases
> > lib/db/dbmi_client/c_openinsert.c | db_open_insert_cursor
> > lib/db/dbmi_client/c_openupdate.c | db_open_update_cursor
> > lib/db/dbmi_client/c_update.c | db_update
> > lib/db/dbmi_client/c_version.c | db_gversion
> > lib/db/dbmi_client/printtab.c | db_print_column_definition
> > lib/db/dbmi_client/printtab.c | db_print_table_definition
> > lib/db/dbmi_driver/d_mkdir.c | db_driver_mkdir
> Aren't these template functions and files to develop new drivers?
No; they are the actual client-side DBMI interface.
I was surprised to find so many of them unused.
