[GRASS-dev] Google Summer Of Code Project
Wolf Bergenheim wolf+grass at bergenheim.net
Tue Apr 17 10:12:16 EDT 2007
On 17.04.2007 16:46, Benjamin Ducke wrote:
> This implies that it's going to be a module that makes use of the
> original GRASS display architecture in the style of d.path.
> May I suggest at least creating a non-interactive, display-independent
> version that simply outputs the path to a new vector map?
> Sth. like v.path.obstacles.
> This way we'll be able to make the contribution more portable, e.g.
> for use with QGIS and GRASS under Windows.
Right. I agree with you Benjamin. it should be a non-interactive module,
and output should be a vector map showing the shortest path. I also
think that maybe it could optionally take multiple start/end points just
like r.path does.
--Wolf
<:3 )---- Wolf Bergenheim ----( 8:>
