[GRASS-dev] Google Summer Of Code Project
Moritz Lennert
mlennert at club.worldonline.be
Tue Apr 17 10:28:56 EDT 2007
On 17/04/07 16:12, Wolf Bergenheim wrote:
> On 17.04.2007 16:46, Benjamin Ducke wrote:
>> This implies that it's going to be a module that makes use of the
>> original GRASS display architecture in the style of d.path.
>> May I suggest at least creating a non-interactive, display-independent
>> version that simply outputs the path to a new vector map?
>> Sth. like v.path.obstacles.
>> This way we'll be able to make the contribution more portable, e.g.
>> for use with QGIS and GRASS under Windows.
> Right. I agree with you Benjamin. it should be a non-interactive module,
> and output should be a vector map showing the shortest path. I also
> think that maybe it could optionally take multiple start/end points just
> like r.path does.
Or like v.net.path, although I would plead for including
startpoint=/endpoint= parameters, not only piping.
Moritz
