[GRASS-dev] Google Summer Of Code Project
Helena Mitasova
hmitaso at unity.ncsu.edu
Tue Apr 17 13:43:11 EDT 2007
We will try to get out a new, more modern data set that is planned as
a replacement for spearfish,
it has been already tested with almost every raster module and most
vector modules,
we just need to cleanup the names and add metadata. The data set has
at least building footprints
so you can generate simple buildings using v.extrude, but I am
working on getting
some real buildings data too. Let me discuss with Markus the best way
to provide
the data set for early testers/developers.
Helena
Helena Mitasova
Dept. of Marine, Earth and Atm. Sciences
1125 Jordan Hall, NCSU Box 8208,
Raleigh NC 27695
http://skagit.meas.ncsu.edu/~helena/
On Apr 17, 2007, at 4:18 AM, maximilian maldacker wrote:
> Hello everyone, my name is Maximilian Maldacker and I'm currently a
> student in Imperial College London studying Mathematics and
> Computer Science. My project on "Shortest path in free (vector)
> space avoiding obstacles module in GRASS" was select by Google
> Summer of Code and I'm looking forward to it :-). I actually start
> on the 28th of May but I thought I'd introduce my self before and
> get involved with the community.
> I have a few question concerning the development of the module. I
> see modules are organized in several folders and I thought I can
> create a new folder in the display folder named d.path_obstacles or
> something similar. Is it sufficient to create a new folder with a
> Makefile inside and a few *.c files to make a new module and will
> it be recognized by the command line?
> The plan for now is to develop a module similar to the d.path one
> except it will start with a vector space containing obstacles
> ( i.e. polygons ) and it will construct a visibility graph out of
> it and compute the shortest path between two given points. Should
> the visibility graph construction algorithm be added to the
> Directed Graph Library?
> What is the best way to test my code? Should I keep a fresh copy of
> GRASS on my computer, modify/create files, compile everything and
> test it using the spearfish example? Or is there another way?
> Thank you for your help and I'm looking forward to help develop GRASS.
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
