[GRASS-dev] [grass-code I][373] NVIZ: max res ppm fails if pwd
is empty
Hamish
hamish_nospam at yahoo.com
Fri Apr 20 02:41:37 EDT 2007
> > code I item #373, was opened at 2007-04-19 18:15
> > Summary: NVIZ: max res ppm fails if pwd is empty
> > In NVIZ if you try and do File->Save Image As->Max res PPM when nviz
> > was started in an new & empty dir you get this tcl error:
> > no files matched glob pattern "*"
> > while executing
> > "glob -directory $cur_dir *"
Glynn:
> Add the -nocomplain switch to the glob command (refresh_file_browser,
> in visualization/nviz/scripts/fileBrowser.tcl).
thanks, fixed in CVS.
Hamish
