[GRASS-dev] [grass-code I][373] NVIZ: max res ppm fails if pwd is
empty
Glynn Clements
glynn at gclements.plus.com
Thu Apr 19 11:38:16 EDT 2007
grass-codei at wald.intevation.org wrote:
> code I item #373, was opened at 2007-04-19 18:15
> Status: Open
> Priority: 2
> Submitted By: Hamish Bowman (hamish)
> Assigned to: Nobody (None)
> Summary: NVIZ: max res ppm fails if pwd is empty
> Issue type: module bug
> Issue status: None
> GRASS version: 6.2.1
> GRASS component: NVIZ
> Operating system: Linux
> Operating system version: debian sarge
> GRASS CVS checkout date, if applies (YYMMDD): 070402
> Initial Comment:
> Hi,
> In NVIZ if you try and do File->Save Image As->Max res PPM when nviz was started in an new & empty dir you get this tcl error:
> no files matched glob pattern "*"
> while executing
> "glob -directory $cur_dir *"
Add the -nocomplain switch to the glob command (refresh_file_browser, in
visualization/nviz/scripts/fileBrowser.tcl).
