[GRASS-dev] [grass-code I][373] NVIZ: max res ppm fails if pwd is empty
grass-codei at wald.intevation.org grass-codei at wald.intevation.org
Thu Apr 19 02:15:59 EDT 2007
code I item #373, was opened at 2007-04-19 18:15
Status: Open
Priority: 2
Submitted By: Hamish Bowman (hamish)
Assigned to: Nobody (None)
Summary: NVIZ: max res ppm fails if pwd is empty
Issue type: module bug
Issue status: None
GRASS version: 6.2.1
GRASS component: NVIZ
Operating system: Linux
Operating system version: debian sarge
GRASS CVS checkout date, if applies (YYMMDD): 070402
Initial Comment:
In NVIZ if you try and do File->Save Image As->Max res PPM when nviz was started in an new & empty dir you get this tcl error:
no files matched glob pattern "*"
    while executing
"glob -directory $cur_dir *"
    (procedure "refresh_file_browser" line 10)
    invoked from within
"refresh_file_browser $w"
    (procedure "create_file_browser" line 91)
    invoked from within
"create_file_browser .file_browser 1"
    invoked from within
".top.menu.file.m.img invoke active"
    ("uplevel" body line 1)
    invoked from within
"uplevel #0 [list $w invoke active]"
    (procedure "tkMenuInvoke" line 47)
    invoked from within
"tkMenuInvoke .top.menu.file.m.img 1
    (command bound to event)
then it takes you to the file picker window.
Hamish
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=373&group_id=21
