[GRASS-dev] nviz crashes on MacOSX
Agustin Diez Castillo
Agustin.Diez at uv.es
Fri Apr 20 07:20:00 EDT 2007
On Apr 19, 2007, at 8:55 PM, William Kyngesburye wrote:
> On Apr 19, 2007, at 12:47 PM, Agustin Diez Castillo wrote:
>> I did compile with TCLTKPREFIX=/usr/local/tcltk. At first it
>> refuses to launch grass, if the terminal was already open nothing
>> happened otherwise I got this:
> How are you starting the GRASS-6.3.app? From the path you are in
> when you fire up gis.m, it looks like you may have started it from
> a Terminal?
Double click
>> After fixing .grassrc GRASS_GUI=tcltk (as expected it changes to
>> text after failure) it starts either the aqua tclktk or the x11
>> one (arbitrarily as far as I can say); after several tryouts I got
>> what I want grass started from x11 but nviz still crashes, I have
>> tried from both the icon and the terminal. Now everything I try
>> but nviz is working
> Does the NVIZ crashlog show the system TclTk still? If so, NVIZ
> itself may have linked to the wrong TclTk, even though the rest of
> GRASS uses the X11 TclTk. Try this in a new Terminal window:
Yes it does
> otool -L /Applications/GRASS-6.3.app/Contents/Resources/etc/nviz2.2/
> nviz
> /usr/local/tcltk/lib/libtcl8.4.dylib and /usr/local/tcltk/lib/
> libtk8.4.dylib should be listed, not the Tcl or Tk frameworks from
> the system.
is pointing to Frameworks
/System/Library/Frameworks/Tk.framework/Versions/8.4/Tk
I will try from the beginning following Glynn suggestions.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> First Pogril: Why is life like sticking your head in a bucket
> filled with hyena offal?
> Second Pogril: I don't know. Why IS life like sticking your head
> in a bucket filled with hyena offal?
> First Pogril: I don't know either. Wretched, isn't it?
> -HitchHiker's Guide to the Galaxy
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20070420/44766f61/attachment.html
