[GRASS-dev] nviz crashes on MacOSX
Agustin Diez Castillo
Agustin.Diez at uv.es
Fri Apr 20 12:59:22 EDT 2007
Now it's working, after cvs update, make distclean, make, sudo make
install.
Same flags, same machine and
export SDKROOT=/Developer/SDKs/MacOSX10.4u.sdk; export CFLAGS="-arch
ppc -arch i386 -isysroot $SDKROOT"; export CXXFLAGS="-arch ppc -arch
i386 -isysroot $SDKROOT"; export LDFLAGS="-arch ppc -arch i386 -
isysroot $SDKROOT"; export NAD2BIN=/Library/Frameworks/PROJ.framework/
Programs/nad2bin
not tcltkprefix.
./configure --with-freetype --with-freetype-includes="/Library/
Frameworks/FreeType.framework/unix/include/freetype2 /Library/
Frameworks/FreeType.framework/unix/include" --with-freetype-libs=/
Library/Frameworks/FreeType.framework/unix/lib --with-gdal=/Library/
Frameworks/GDAL.framework/Programs/gdal-config --with-proj --with-
proj-includes=/Library/Frameworks/PROJ.framework/unix/include --with-
proj-libs=/Library/Frameworks/PROJ.framework/unix/lib --with-proj-
share=/Library/Frameworks/PROJ.framework/Resources/proj --with-jpeg-
includes=/Library/Frameworks/UnixImageIO.framework/unix/include --
with-jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --
with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/
include --with-png-libs=/Library/Frameworks/UnixImageIO.framework/
unix/lib --with-tiff-includes=/Library/Frameworks/
UnixImageIO.framework/unix/include --with-tiff-libs=/Library/
Frameworks/UnixImageIO.framework/unix/lib --with-postgres-includes=/
usr/local/pgsql/include --with-postgres-libs=/usr/local/pgsql/lib --
without-mysql --with-odbc --with-sqlite --with-sqlite-libs=/Library/
Frameworks/SQLite3.framework/unix/lib --with-sqlite-includes=/Library/
Frameworks/SQLite3.framework/unix/include --with-fftw-includes=/
Library/Frameworks/FFTW3.framework/unix/include --with-fftw-libs=/
Library/Frameworks/FFTW3.framework/unix/lib --with-cxx --with-tcltk-
includes=/usr/local/tcltk/include --with-tcltk-libs=/usr/local/tcltk/
lib --with-x --with-motif --without-glw --with-opengl=x11 --with-
opengl-libs=/usr/X11R6/lib --without-readline --prefix=/Applications
--enable-macosx-app
> On Apr 20, 2007, at 6:03 AM, Agustin Diez Castillo wrote:
>> I did NOT start from the terminal, I doubled click on the
>> application. The Xlib message only showed up once, the tcltk
>> messages several times but they are gone now. However nviz still
>> crashes.
>> http://smigol2.uv.es/nviz_crashing.mov
> Sorry. But now it's making sense - as Glynn suggested, somehow
> during the build NVIZ is linking to /usr/libtcl and /usr/libtk.
> These are the symlinks in the system to the system Tcl and Tk
> frameworks. As far as Glynn's suggestion of creating these
> symlinks to /usr/local/tcltk copies, you shouldn't mess with system
> stuff (/usr/lib).
> What is the link command show for nviz when you build grass? it's
> built as nvwish so search for that in the make output.
> There should be no -L/usr/lib in there. That's a default dir for
> GCC and manually adding it somehow can mess up linking priorities,
> like what is happening here.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "This is a question about the past, is it? ... How can I tell that
> the past isn't a fiction designed to account for the discrepancy
> between my immediate physical sensations and my state of mind?"
> - The Ruler of the Universe
