[GRASS-dev] [patch] Use <termios.h> in intr_char.c
Sat Apr 21 12:28:10 EDT 2007
Hamish wrote:
> Maciej Sieczka wrote:
> > My email server tends to re-send a random message from time to time.
> > Ed's message was one such.
> I've just received it too.
> <from the OP email header info>
> Received: from grass.itc.it (localhost.localdomain [127.0.0.1])	by grass.itc.it (8.13.1/8.13.1) with ESMTP id l3KDiAoO027865;	Fri, 20 Apr 2007 15:44:15 +0200
> Received: from palm.hoeg.nl (palm.hoeg.nl [83.98.131.212])	by grass.itc.it (8.13.1/8.13.1) with ESMTP id l2QKs5W5013503	for <grass-dev at grass.itc.it>; Mon, 26 Mar 2007 22:54:05 +0200
> the hold-up seems to have been in Italy.
Same here:
> apparently Glynn received it earlier:
No, I received (and replied to) a similar message sent by the bug
tracker:
	http://grass.itc.it/pipermail/grass-dev/2007-March/030047.html
	http://grass.itc.it/pipermail/grass-dev/2007-March/030057.html
