[GRASS-dev] [patch] Use <termios.h> in intr_char.c
Markus Neteler neteler at itc.it
Sat Apr 21 17:06:37 EDT 2007
On Sun, Apr 22, 2007 at 12:14:01AM +1200, Hamish wrote:
> Maciej Sieczka wrote:
> > My email server tends to re-send a random message from time to time.
> > Ed's message was one such.
> I've just received it too.
> <from the OP email header info>
> Received: from grass.itc.it (localhost.localdomain [127.0.0.1])	by grass.itc.it (8.13.1/8.13.1) with ESMTP id l3KDiAoO027865;	Fri, 20 Apr 2007 15:44:15 +0200
> Received: from palm.hoeg.nl (palm.hoeg.nl [83.98.131.212])	by grass.itc.it (8.13.1/8.13.1) with ESMTP id l2QKs5W5013503	for <grass-dev at grass.itc.it>; Mon, 26 Mar 2007 22:54:05 +0200
> the hold-up seems to have been in Italy.
Mea culpa (AFAIK):
This mail got trapped in Mailman since the sender wasn't subscribed
to the list. To not discard the mail, I approved it and wrote to
the person to subscribe to follow further conversation.
Usually I reject such mails. Probably I should have done so here, too.
But there us always the not so low probability that senders just
throw it away.
Well: sorry for the mess. But I don't manage to check the mailman
queues daily. I guess I will tend to always reject now.
Markus
> apparently Glynn received it earlier:
> CVS log for grass6/lib/gis/intr_char.c
>  Revision 2.2, Fri Mar 30 09:30:02 2007 UTC (3 weeks, 1 day ago)
>  Changes since 2.1: +9 -1 lines
>  Use termios if available
> Hamish
> grass-dev mailing list
> http://grass.itc.it/mailman/listinfo/grass-dev
Markus Neteler  <neteler itc it>  http://mpa.itc.it/markus/
FBK-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
