[GRASS-dev] [grass-code I][377] d.vect map disp=dir now broken:
G_plot_icon() bug?
grass-codei at wald.intevation.org
Sat Apr 21 16:05:01 EDT 2007
code I item #377, was opened at 2007-04-21 22:05
Status: Open
Priority: 3
Submitted By: Markus Neteler (markusn)
Assigned to: Nobody (None)
Summary: d.vect map disp=dir now broken: G_plot_icon() bug?
Issue type: module bug
Issue status: None
GRASS version: CVS HEAD
GRASS component: None
Operating system: all
Operating system version:
GRASS CVS checkout date, if applies (YYMMDD):
Initial Comment:
Since a few days the "disp=dir" no longer works.
I recall to have seen some G_plot_icon() modifications. Could this
be related? The positioning is right but the symbol invisible:
#spearfish
d.vect roads
d.vect roads disp=dir
-> directional arrow no more visible
This functionality is important for graph related work such as LRS or vector network analysis.
Markus
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=377&group_id=21
