[GRASS-dev] Re: minor issue with compiling Mac version of GRASS 6.3
cvs
William Kyngesburye
woklist at kyngchaos.com
Sun Apr 22 23:24:06 EDT 2007
On Apr 22, 2007, at 10:03 PM, Michael Barton wrote:
> Something I’ve been meaning to mention for awhile (but haven’t
> gotten around to it because it is fairly minor) is that every time
> I compile after a make distclean or make clean, I have ...
Scoll up in the make output to find why these failed (I usually Find
the string '***' to locate make errors).
> Errors in:
> /Users/cmbarton/grass_dev/grass6/lib/proj
> /Users/cmbarton/grass_dev/grass6/gui/tcltk/d.m
> If I change to the relevant directories and run make, they compile
> just fine, and I have no more problem until I do a distclean or
> clean again.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an
illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
