[GRASS-dev] DBMI trouble compiling on Win32
Benjamin Ducke
benjamin.ducke at ufg.uni-kiel.de
Mon Apr 23 09:02:23 EDT 2007
Thanks, Glynn for the quick reply.
This fixed things in part. However, now I have a problem with the DBMI
lib:
cd /src/grass6/lib/db/dbmi_client
make
gives me:
gcc -I/src/grass6/dist.i686-pc-mingw32/include -I/include
-I/local/include -g -O2 -I/include -I/local/include
-DPACKAGE=\""grasslibs"\" -I../dbmi_base -DPACKAGE=\""grasslibs"\"
-I/src/grass6/dist.i686-pc-mingw32/include \
-o OBJ.i686-pc-mingw32/start.o -c start.c
start.c: In function `db_start_driver':
start.c:157: error: `have_stdin' undeclared (first use in this function)
start.c:157: error: (Each undeclared identifier is reported only once
start.c:157: error: for each function it appears in.)
start.c:157: error: `have_stdout' undeclared (first use in this function)
start.c:162: error: `stdin_fd' undeclared (first use in this function)
start.c:168: error: `stdin_orig' undeclared (first use in this function)
start.c:185: error: `stdout_fd' undeclared (first use in this function)
start.c:191: error: `stdout_orig' undeclared (first use in this function)
make[1]: *** [OBJ.i686-pc-mingw32/start.o] Error 1
make[1]: Leaving directory `/src/grass6/lib/db/dbmi_client'
Maybe something needs to be fixed in the configure script for Win32?
Thanks,
Benjamin
Glynn Clements wrote:
> Benjamin Ducke wrote:
>> I am trying to compile yesterday's CVS sources on Win32 using MSYS and
>> MingW (3.4.2).
>> When the make script should link the gis lib objs (and other libs), I
>> get this:
>> OBJ.i686-pc-mingw32/open_misc.o(.data+0x0): In function `G__open_misc':
>> C:/msys/src/grass6/lib/gis/open_misc.c:45: multiple definition of `_fmode'
>> OBJ.i686-pc-mingw32/open.o(.data+0x0):C:/msys/src/grass6/lib/gis/open.c:98:
>> first defined here
>> collect2: ld returned 1 exit status
>> make[2]: ***
>> [/src/grass6/dist.i686-pc-mingw32/lib/libgrass_gis.6.3.cvs.dll] Error 1
>> I updated from CVS ca. 18 hours ago and did a "make distclean" and "make
>> clean" before running the configure script.
> I've removed both occurrences of _fmode from libgis (in any case,
> defining it inside a DLL doesn't work). _fmode should be defined by
> linking against $(FMODE_OBJ).
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
