[GRASS-dev] DBMI trouble compiling on Win32
Moritz Lennert mlennert at club.worldonline.be
Mon Apr 23 10:45:52 EDT 2007
On 23/04/07 15:02, Benjamin Ducke wrote:
> Thanks, Glynn for the quick reply.
> This fixed things in part. However, now I have a problem with the DBMI
> lib:
> cd /src/grass6/lib/db/dbmi_client
> make
> gives me:
> gcc -I/src/grass6/dist.i686-pc-mingw32/include -I/include
> -I/local/include -g -O2  -I/include -I/local/include
> -DPACKAGE=\""grasslibs"\"   -I../dbmi_base    -DPACKAGE=\""grasslibs"\"
>  -I/src/grass6/dist.i686-pc-mingw32/include \
>         -o OBJ.i686-pc-mingw32/start.o -c start.c
> start.c: In function `db_start_driver':
> start.c:157: error: `have_stdin' undeclared (first use in this function)
> start.c:157: error: (Each undeclared identifier is reported only once
> start.c:157: error: for each function it appears in.)
> start.c:157: error: `have_stdout' undeclared (first use in this function)
> start.c:162: error: `stdin_fd' undeclared (first use in this function)
> start.c:168: error: `stdin_orig' undeclared (first use in this function)
> start.c:185: error: `stdout_fd' undeclared (first use in this function)
> start.c:191: error: `stdout_orig' undeclared (first use in this function)
> make[1]: *** [OBJ.i686-pc-mingw32/start.o] Error 1
> make[1]: Leaving directory `/src/grass6/lib/db/dbmi_client'
> Maybe something needs to be fixed in the configure script for Win32?
This seems to come from Brad's latest change to start.c:
@@ -33,9 +38,6 @@
      int stat;
      dbConnection connection;
      char ebuf[5];
-    int stdin_orig, stdout_orig;
-    int have_stdin, have_stdout;
-    int stdin_fd, stdout_fd;
Brad, any special reason for this, or did you just not see that these
are used in the #ifdef __MINGW32__ which starts at line 117 ?
Moritz
