[GRASS-dev] DBMI trouble compiling on Win32
Glynn Clements
glynn at gclements.plus.com
Mon Apr 23 14:18:13 EDT 2007
Moritz Lennert wrote:
> > This fixed things in part. However, now I have a problem with the DBMI
> > lib:
> > cd /src/grass6/lib/db/dbmi_client
> > make
> > gives me:
> > gcc -I/src/grass6/dist.i686-pc-mingw32/include -I/include
> > -I/local/include -g -O2 -I/include -I/local/include
> > -DPACKAGE=\""grasslibs"\" -I../dbmi_base -DPACKAGE=\""grasslibs"\"
> > -I/src/grass6/dist.i686-pc-mingw32/include \
> > -o OBJ.i686-pc-mingw32/start.o -c start.c
> > start.c: In function `db_start_driver':
> > start.c:157: error: `have_stdin' undeclared (first use in this function)
> > start.c:157: error: (Each undeclared identifier is reported only once
> > start.c:157: error: for each function it appears in.)
> > start.c:157: error: `have_stdout' undeclared (first use in this function)
> > start.c:162: error: `stdin_fd' undeclared (first use in this function)
> > start.c:168: error: `stdin_orig' undeclared (first use in this function)
> > start.c:185: error: `stdout_fd' undeclared (first use in this function)
> > start.c:191: error: `stdout_orig' undeclared (first use in this function)
> > make[1]: *** [OBJ.i686-pc-mingw32/start.o] Error 1
> > make[1]: Leaving directory `/src/grass6/lib/db/dbmi_client'
> > Maybe something needs to be fixed in the configure script for Win32?
> This seems to come from Brad's latest change to start.c:
> @@ -33,9 +38,6 @@
> int stat;
> dbConnection connection;
> char ebuf[5];
> - int stdin_orig, stdout_orig;
> - int have_stdin, have_stdout;
> - int stdin_fd, stdout_fd;
> Brad, any special reason for this, or did you just not see that these
> are used in the #ifdef __MINGW32__ which starts at line 117 ?
Almost certainly the latter. I've restored the variables,
conditionalised upon "#ifdef __MINGW32__" to prevent "unused variable"
warnings on other platforms (which is probably the reason that they
were removed).
