[GRASS-dev] DBMI trouble compiling on Win32
Benjamin Ducke benjamin.ducke at ufg.uni-kiel.de
Tue Apr 24 03:13:04 EDT 2007
OK, this seems to have done the trick.
Thanks for the quick help.
In the future, I will try to find more time to compile and test the CVS
version of GRASS more frequently on Win32, so problems like these will
surface early.
Benjamin
Glynn Clements wrote:
> Moritz Lennert wrote:
>>> This fixed things in part. However, now I have a problem with the DBMI
>>> lib:
>>> cd /src/grass6/lib/db/dbmi_client
>>> make
>>> gives me:
>>> gcc -I/src/grass6/dist.i686-pc-mingw32/include -I/include
>>> -I/local/include -g -O2  -I/include -I/local/include
>>> -DPACKAGE=\""grasslibs"\"   -I../dbmi_base    -DPACKAGE=\""grasslibs"\"
>>>  -I/src/grass6/dist.i686-pc-mingw32/include \
>>>         -o OBJ.i686-pc-mingw32/start.o -c start.c
>>> start.c: In function `db_start_driver':
>>> start.c:157: error: `have_stdin' undeclared (first use in this function)
>>> start.c:157: error: (Each undeclared identifier is reported only once
>>> start.c:157: error: for each function it appears in.)
>>> start.c:157: error: `have_stdout' undeclared (first use in this function)
>>> start.c:162: error: `stdin_fd' undeclared (first use in this function)
>>> start.c:168: error: `stdin_orig' undeclared (first use in this function)
>>> start.c:185: error: `stdout_fd' undeclared (first use in this function)
>>> start.c:191: error: `stdout_orig' undeclared (first use in this function)
>>> make[1]: *** [OBJ.i686-pc-mingw32/start.o] Error 1
>>> make[1]: Leaving directory `/src/grass6/lib/db/dbmi_client'
>>> Maybe something needs to be fixed in the configure script for Win32?
>> This seems to come from Brad's latest change to start.c:
>> @@ -33,9 +38,6 @@
>>       int stat;
>>       dbConnection connection;
>>       char ebuf[5];
>> -    int stdin_orig, stdout_orig;
>> -    int have_stdin, have_stdout;
>> -    int stdin_fd, stdout_fd;
>> Brad, any special reason for this, or did you just not see that these
>> are used in the #ifdef __MINGW32__ which starts at line 117 ?
> Almost certainly the latter. I've restored the variables,
> conditionalised upon "#ifdef __MINGW32__" to prevent "unused variable"
> warnings on other platforms (which is probably the reason that they
> were removed).
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
