[GRASS-dev] numeric-numpy-scipy for graphs?
John Gillette JGillette at rfmd.com
Mon Apr 23 13:52:41 EDT 2007
What does "DC" stand for?
> -----Original Message-----
> From: grass-dev-bounces at grass.itc.it
> [mailto:grass-dev-bounces at grass.itc.it] On Behalf Of Glynn Clements
> Sent: Monday, April 23, 2007 5:32 AM
> To: Paul Kelly
> Cc: grassgui at grass.itc.it; Michael Barton; Hamish;
> grass-dev at grass.itc.it
> Subject: Re: [GRASS-dev] numeric-numpy-scipy for graphs?
> Paul Kelly wrote:
> > > In fact, we can do considerably more now with the wxPython (and
> > > TclTk) drawing commands to than is available in d.graph or
> > > d.linegraph, even with your nice enhancements.
> > > In the case of histogramming and profiling, it seems a better
> > > display to have them come up in a separate window (like
> is now the
> > > case with the TclTk profiling module) than have them
> rendered like a
> > > map in the main display (like we do now for d.histogram in the
> > > current TclTk GUI). Rendering maps is complex and it doesn't seem
> > > efficient to have to go through the same complex
> procedures to draw
> > > a histogram or profile that doesn't need to be drawn
> georeferenced.
> > Another thought - with the enhancements to the display
> architecture in
> > progress/idea stage
> Idea, currently. I need to introduce non-trivial API breakage
> in order to go much further. Mainly, switching to
> floating-point coordinates and adding begin/end operations to
> the move/cont and raster primitives.
> > it might actually be possible to produce better quality graphs for
> > inclusion in reports/papers etc. using the existing display
> > architecture. I'm thinking of the move towards PostScript
> as a display
> > output format.
> Certainly, I want (decent) PostScript output to at least be
> an option.
> The main question is whether we can abandon other formats, i.e.
> whether modules can rely upon being able to use the full
> feature set (e.g. arbitrary clip paths, rotation/scaling of
> all output, pattern fills etc), or whether they will be
> limited to a common-denominator subset.
> > I imagine with pop-up Windows in the GUI with histograms etc. you
> > would be limited to printing the thing as a raster graphic
> at the same
> > resolution as the screen?
> Not quite. I'm assuming that lines, polygons etc wouldn't be
> rasterised when using a print DC, but you're still stuck with
> coordinates on integer boundaries (and a fairly primitive API).
> This is one of the main distinctions between an "ideal"
> graphics API (PostScript, OpenGL) and an "adequate for GUI
> use" API (X11, Windows GDI).
> [FWIW, the wx API is heavily based upon Windows' GDI, which
> hasn't really changed much since Windows 1.0.]
> > Not so good. Unless those
> > new python modules you're looking at perhaps have an option
> to save as
> > postscript (I mean proper line-graphics postscript) for printing.
> wx has PostScriptDC and PrinterDC, which allow you to use the
> same code as for drawing on a screen DC. Not all operations
> will work on such contexts, e.g. you can't use raster ops
> (XOR-plotting etc) in PostScript. And you're still limited to
> the standard DC methods, e.g.
> no rotated images (NT/2K/XP has this, 95/98/ME doesn't, nor does X).
> > And of
> > course if you use GRASS modules to produce the graphs then as Glynn
> > says it is also possible to produce them from scripts,
> which is rather
> > important. (Rather than having all this functionality tied
> up in the
> > GUI and having to re-implement it if we change the GUI).
> > > For this reason, it seems better to do these kinds of
> analyses with
> > > the gui tools, using underlying GRASS modules like
> r.profile and r.stats.
> > I agree it "seemed" better/tidier/neater to me at first, but if we
> > consider the display architecture is being enhanced beyond it's old
> > clunky state it may not be as logical is it first seemed?
> +1 ;)
> Glynn Clements <glynn at gclements.plus.com>
> grass-dev mailing list
> http://grass.itc.it/mailman/listinfo/grass-dev
