[GRASS-dev] g.copy bug?
Markus Neteler neteler at itc.it
Mon Apr 23 15:08:47 EDT 2007
On Mon, Apr 23, 2007 at 05:31:26PM +0200, Martin Wegmann wrote:
> Hello,
> g.copy from mapsetA -> mapsetB does not work witht the most current cvs
> version.
> if I run g.copy rast=old at mapsetX,test1725heute
> d.rast test1725heute
> WARNING: can't read range file for [test1725heute in habitat_amount]
> WARNING: color support for [test1725heute] in mapset [habitat_amount]
>          missing
> ERROR: Color file for [test1725heute] not available
Martin,
most likely a "make distclean" and full recompile will
cure the problem. Did you try this?
Markus
