[GRASS-dev] g.copy bug?
Martin Wegmann
wegmann at biozentrum.uni-wuerzburg.de
Tue Apr 24 04:24:44 EDT 2007
On Monday 23 April 2007 21:08, Markus Neteler wrote:
> On Mon, Apr 23, 2007 at 05:31:26PM +0200, Martin Wegmann wrote:
> > Hello,
> > g.copy from mapsetA -> mapsetB does not work witht the most current cvs
> > version.
> > if I run g.copy rast=old at mapsetX,test1725heute
> > d.rast test1725heute
> > WARNING: can't read range file for [test1725heute in habitat_amount]
> > WARNING: color support for [test1725heute] in mapset [habitat_amount]
> > missing
> > ERROR: Color file for [test1725heute] not available
> Martin,
> most likely a "make distclean" and full recompile will
> cure the problem. Did you try this?
my script does:
make clean
make distclean
cvs update -dP grass6
./configure --with-tcltk-includes=/usr/include/tcl8.4 --with-postgres-includes=/usr/include/postgresql --with-gdal=/usr/local/bin/gdal-config --enable-largefile
make
make install
I am recompiling it again and perhaps I'll redo it by-hand if it does not work
afterwards.
Martin
> Markus
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
