[GRASS-dev] [grass-code R][380] r.in.wms - support curl as alternative to wget
grass-coder at wald.intevation.org grass-coder at wald.intevation.org
Tue Apr 24 13:29:46 EDT 2007
code R item #380, was opened at 2007-04-24 12:29
Status: Open
Priority: 3
Submitted By: William Kyngesburye (kyngchaos)
Assigned to: Nobody (None)
Summary: r.in.wms - support curl as alternative to wget
Issue status: None
GRASS component: raster
Operating system: all
Operating system version:
Initial Comment:
Some platforms may not include wget, but do have curl (ie Mac OS X).  From what I've found, they provide the same functionality, or at least what is needed for r.in.wms.  This would reduce the required extra software that must be located and installed on those systems.
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=188&aid=380&group_id=21
