[GRASS-dev] [grass-code I][379] r.in.wms incorrect flag
Daniel Calvelo dca.gis at gmail.com
Wed Apr 25 14:37:16 EDT 2007
If this is a BSD sed issue (which it seems to be, this being MacOSX),
the only portable thingie is:
s/[Ee][Vv][Ee][Rr][Yy]/possible capitalization as alternations/
As a MacOSX-only workaround, define SED="perl -pe" then call $SED
's/aa/AA/i' instead of sed 's/aa/AA/i', which works if:
1) Perl is installed (always true for MacOSX and linuxen)
2) A compatible subset of commands (e.g. simple s///i) is used in the sed code
3) The regexps don't use backreferences and capturing parenthesis
(which works differently in perl and sed)
BTW does BSD sed recognize \w?
OTOH, given that in r.in.wms the /i flags are used after a grep which
IS case-sensitive, they can be removed, AFAICT. Can anybody try this?
Daniel.
On 4/25/07, Hamish <hamish_nospam at yahoo.com> wrote:
> http://wald.intevation.org/tracker/?func=detail&atid=204&aid=379&group_id=21
> > code I item #379, was opened at 2007-04-24 19:03
> > Summary: r.in.wms incorrect flag
> > Operating system: MacOS X
> > Operating system version: 10.4.9
> > WARNING: xml2 NOT avaliable
> > sed: sed: 1: "s/<Layer .*>/LAYER:/i
> > ": bad flag in substitute command: 'i'
> > 1: "s/<Name>\s*\(\w*\)/~\1~ ...": bad flag in substitute command: 'i'
> > sed: 1: "s/<\/Name>\n//ig
> > ": bad flag in substitute command: 'i'sed: 1: "s/<\/Layer.*>//i
> > sed: 1: "s/<\/*.*\/*\/*>//i
> > sed: 1: "s/<\/Title>//i
> > sed: 1: "s/<Style>\n*\s*\(\w*\)/ ...": bad flag in substitute command:
> > 'i' sed: 1: "s/<Title>\(.*\)<\/Title ...": bad flag in substitute
> > command: 'i' sed: 1: "s/<\/Style>//i
> > The problem seems to be the alternative sed command used.  That /i is
> > not a valid flag to the s/ sed command.
> from the Sed FAQ:
>   http://sed.sourceforge.net/sedfaq3.html#s3.1.3
> --quoted--
> GNU sed 3.02 and ssed also offer the /I switch for doing
> a case-insensitive match. For example,
>      echo ONE TWO | gsed "s/one/unos/I"      # prints
> "unos TWO"
> --endquote--
> anyone know a regex solution that's more portable than s///i?
> Hamish
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
-- Daniel Calvelo Aros
