[GRASS-dev] g.remove with @mapset problem
Glynn Clements
glynn at gclements.plus.com
Tue Apr 24 14:31:26 EDT 2007
Martin Wegmann wrote:
> I you use the GUI of g.remove and select some raster files it adds the @mapset
> as well which causes an error when executing this command:
> copy/paste of GUI command:
> g.remove rast=dispersalmap_missing_2 at march07
> Removing raster <dispersalmap_missing_2 at march07>
> Illegal filename. Character <@> not allowed.
When did you last update? I think that I fixed this one on the 20th.
