[GRASS-dev] g.remove with @mapset problem
Martin Wegmann wegmann at biozentrum.uni-wuerzburg.de
Wed Apr 25 05:17:06 EDT 2007
On Tuesday 24 April 2007 20:31, Glynn Clements wrote:
> Martin Wegmann wrote:
> > I you use the GUI of g.remove and select some raster files it adds the
> > @mapset as well which causes an error when executing this command:
> > copy/paste of GUI command:
> > g.remove rast=dispersalmap_missing_2 at march07
> > Removing raster <dispersalmap_missing_2 at march07>
> > Illegal filename. Character <@> not allowed.
> When did you last update? I think that I fixed this one on the 20th.
I did a cvs update again and compiled it again by hand
(rm -rf /usr/local/grass6.... ), make distclean, ./configure, make, make
install now g.remove works but the g.copy problem remains.
thanks, Martin
