[GRASS-dev] g.copy bug?
Maciej Sieczka
tutey at o2.pl
Wed Apr 25 12:08:35 EDT 2007
Martin Wegmann wrote:
> GRASS 6.3.cvs (spearfish60):~ > gdb g.copy
> GNU gdb 6.6-debian
> Copyright (C) 2006 Free Software Foundation, Inc.
> GDB is free software, covered by the GNU General Public License, and you are
> welcome to change it and/or distribute copies of it under certain conditions.
> Type "show copying" to see the conditions.
> There is absolutely no warranty for GDB. Type "show warranty" for details.
> This GDB was configured as "i486-linux-gnu"...
> Using host libthread_db library "/lib/i686/cmov/libthread_db.so.1".
> (gdb) run rast=aspect at PERMANENT,testcopy7
> Starting program: /usr/local/grass-6.3.cvs/bin/g.copy
> Failed to read a valid object file image from memory.
> [Thread debugging using libthread_db enabled]
> [New Thread -1225282800 (LWP 13535)]
> Copy raster <aspect at PERMANENT> to current mapset as <testcopy7>
> Program received signal SIGSEGV, Segmentation fault.
FWIW, I can't reproduce this.
(current GRASS 6.3 CVS built and running on Ubuntu Dapper, 32 bit, GCC
4.0.3, Pentium M, kernel 2.6.15-28-686)
Maciek
