[GRASS-dev] g.copy vect/DBF problem & suggestion
Markus Neteler
neteler at itc.it
Thu Apr 26 09:42:28 EDT 2007
Markus Neteler wrote on 04/26/2007 12:23 AM:
> Hi,
> copying a vector map into a mapset where the DBF driver
> is defined but the dbf/ directory still absent (for
> whatsoever reason), g.copy bails out with
> g.copy vect=zipcodes_wake,myzipcodes_wake
> Copy vector <zipcodes_wake at PERMANENT> to current mapset as
> <myzipcodes_wake>
> DBMI-DBF driver error:
> Cannot open dbf database: /home/neteler/grassdata/nc_spm_04/neteler/dbf/
> WARNUNG: Cannot open database
> '/home/neteler/grassdata/nc_spm_04/neteler/dbf/'
> no database is open
> WARNUNG: Cannot copy table
> WARNUNG: Cannot copy <zipcodes_wake at PERMANENT> to current mapset as
> <myzipcodes_wake>
> In db/drivers/dbf/db.c, I suggest to add a test around line 89 with
> # pseudocode
> if LOCATION/MAPSET/dbf/ does not exist
> create it
> How to implement this in a portable way?
Inspired by lib/gis/ code, I have now submitted a fix for this.
diff attached.
Markus
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
? OBJ.x86_64-unknown-linux-gnu
? dc.diff
Index: db.c
RCS file: /grassrepository/grass6/db/drivers/dbf/db.c,v
retrieving revision 1.15
diff -u -r1.15 db.c
--- db.c 26 Apr 2007 13:02:12 -0000 1.15
+++ db.c 26 Apr 2007 13:40:31 -0000
@@ -17,6 +17,9 @@
#include <stdlib.h>
#include <string.h>
#include <dirent.h>
+#include <sys/types.h>
+#include <sys/stat.h>
+#include <errno.h>
#include <grass/dbmi.h>
#include <grass/gis.h>
#include "globals.h"
@@ -78,11 +81,23 @@
G_debug(2, "db.name = %s", db.name);
+ errno = 0;
dir = opendir(db.name);
if (dir == NULL) {
- append_error("Cannot open dbf database: %s\n", name);
- report_error();
- return DB_FAILED;
+ if (errno == ENOENT) {
+ int status;
+ status = G_mkdir(db.name);
+ if (status != 0) { /* mkdir failed */
+ append_error("Cannot create dbf database: %s\n", name);
+ report_error();
+ return DB_FAILED;
+ } else { /* some other problem */
+ append_error("Cannot open dbf database: %s\n", name);
+ report_error();
+ return DB_FAILED;
while ((ent = readdir(dir))) {
