[GRASS-dev] backporting new v.digit to the 6.2 branch
Glynn Clements
glynn at gclements.plus.com
Thu Apr 26 22:35:53 EDT 2007
Hamish wrote:
> > > what's more, v.digit in GRASS 6.3 segfaults on startup for me
> > > currently.
> > Oh. For me it works OK in 6.3.
> > > Not an encouraging sign for the 6.3 version being mature enough to
> > > backport.
> > > g.region rast=roads
> > > v.digit -n test_dig_area
> > > New empty map created.
> > > ###wish gui flashes up then disappears###
> > > Segmentation fault
> > > gdb:
> > > G63> gdb `which v.digit`
> > > (gdb) run -n test_map1
> > > Starting program:
> > > /usr/local/src/grass/grass63/dist.i686-pc-linux-gnu/bin/v.digit -n
> > > test_map1 [Thread debugging using libthread_db enabled]
> > > [New Thread 16384 (LWP 9024)]
> > > Program received signal SIGSEGV, Segmentation fault.
> > > [Switching to Thread 16384 (LWP 9024)]
> > > 0x406e4a02 in Tcl_ParseCommand () from /usr/lib/libtcl8.3.so.1
> > > same thing starting with:
> > > G63> GRASS_WISH=wish8.4 v.digit -n test_map2
> > FWIW I build and run against tcl/tk 8.4.12. No crashes here.
> Now I recall this is C+Tcl, so the runtime wish doesn't matter as much,
FWIW, the runtime "wish" doesn't matter *at all*.
I don't get a crash here (Tcl/Tk 8.4), so unless someone who does get
a crash can provide a backtrace, there isn't much that we can do about
it.
It might be worth checking programs which use the form library, e.g.
d.what.vect and v.what.
