[GRASS-dev] backporting new v.digit to the 6.2 branch
Hamish
hamish_nospam at yahoo.com
Fri Apr 27 00:24:06 EDT 2007
Glynn Clements wrote:
> Hamish wrote:
> > > > what's more, v.digit in GRASS 6.3 segfaults on startup for me
> > > > currently.
> > > Oh. For me it works OK in 6.3.
> > > > Not an encouraging sign for the 6.3 version being mature enough
> > > > to backport.
> > > > g.region rast=roads
> > > > v.digit -n test_dig_area
> > > > New empty map created.
> > > > ###wish gui flashes up then disappears###
> > > > Segmentation fault
> > > > gdb:
> > > > G63> gdb `which v.digit`
> > > > (gdb) run -n test_map1
> > > > Starting program:
> > > > /usr/local/src/grass/grass63/dist.i686-pc-linux-gnu/bin/v.digit
> > > > -n test_map1 [Thread debugging using libthread_db enabled]
> > > > [New Thread 16384 (LWP 9024)]
> > > > Program received signal SIGSEGV, Segmentation fault.
> > > > [Switching to Thread 16384 (LWP 9024)]
> > > > 0x406e4a02 in Tcl_ParseCommand () from /usr/lib/libtcl8.3.so.1
> > > > same thing starting with:
> > > > G63> GRASS_WISH=wish8.4 v.digit -n test_map2
> > > FWIW I build and run against tcl/tk 8.4.12. No crashes here.
> > Now I recall this is C+Tcl, so the runtime wish doesn't matter as
> > much,
> FWIW, the runtime "wish" doesn't matter *at all*.
> I don't get a crash here (Tcl/Tk 8.4), so unless someone who does get
> a crash can provide a backtrace, there isn't much that we can do about
> it.
backtrace is here:
http://grass.itc.it/pipermail/grass-dev/2007-April/030641.html
driver.c line 58, in get_window():
Tcl_Eval(Toolbox, "list 0 [winfo height .screen.canvas] 0 [winfo width .screen.canvas]");
after that, I'm not sure where to look.
> It might be worth checking programs which use the form library, e.g.
> d.what.vect and v.what.
d.what.vect is working fine. v.what segfaulted, but that was another
issue which I've just fixed in CVS. Now v.what works ok.
Hamish
