[GRASS-dev] font path question for Linux and Windows
Michael Barton
michael.barton at asu.edu
Mon Apr 30 16:24:38 EDT 2007
Some of these probably won't display with GRASS's TrueType drivers.
Trying to find all the potentially useable fonts on all kinds of systems is
indeed a laudable task--and clearly a complex one. My goal is somewhat more
modest. I just need to make it easier for people to find where their fonts
are located so that they can manually pick one they want to use for a
session default.
This is pretty easy for Mac and Windows--although recognizing that not all
fonts will be in 'standard' locations. It is more complicated for Linux,
where there are several 'standard' locations depending on flavor. What would
further make this process more convenient is to be able to set a desired
font path and desired default that will persist beyond each GUI or GRASS
session.
Michael
On 4/30/07 12:54 PM, "William Kyngesburye" <woklist at kyngchaos.com> wrote:
> On Apr 30, 2007, at 1:50 PM, Michael Barton wrote:
>> Are any of the fonts normally in the /Library/Fonts directory of
>> OSX NOT
>> freetype? Would there be any problem with a non-freetype font
>> sneaking into
>> freetypecap beyond it simply not displaying?
>> If the answer to these is generally negative, why not just grab all
>> the
>> fonts from /LibraryFonts (and maybe $HOME/Library/Fonts) for
>> freetypecap and
>> not worry about whether they have a .ttf extension or not.
>> Michael
> This is related to another font item that I hesitated to bring up
> since the focus has been on TT fonts - postscript and opentype (which
> are really just font packages for PS and TT) fonts. Sure, assuming
> all files are font files may be OK, and thus get all types of fonts
> (PS and TT). But with PS fonts, there are multiple files per font face.
> On OSX there is the bitmap/suitcase that has the pre-made bitmaps for
> certain sizes and references to all the faces, and then each face has
> its own PS font file. You normally reference a suitcase font from
> the suitcase file and a face index or name, not the PS file (though
> FT may be able to do that also, I don't know). And on other
> platforms PS fonts are usually split into individual faces, but can
> also have more than one file per face - pfb/pfa, afm and possibly
> others.
> You would have to filter out the extras or you will get a mess of
> duplicate or unusable fonts.
> One possibility would be to test each font file found with freetype
> calls, but this might add more time to the startup than simply
> listing files, and I don't know if it could be done from a script -
> mkftcap might need to be a C prog.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Oh, look, I seem to have fallen down a deep, dark hole. Now what
> does that remind me of? Ah, yes - life."
> - Marvin
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
