[GRASS-dev] [grass-code I][431] g.copy segmentation fault
vwichmann wichmann at laserdata.at
Wed Aug 1 07:31:54 EDT 2007
Glynn Clements wrote:
>>> It might help if you re-compile the general/manage directory without
>>> optimisation, e.g.:
>>> 	make -C general/manage clean
>>> 	make -C general/manage CFLAGS1='-g'
>>> That will certainly make it easier to debug; OTOH, it might simply
>>> make the bug disappear.
... just as a follow up: discussion off-list showed that this solved the
problem for several people who encountered this error too.
Volker
View this message in context: http://www.nabble.com/-grass-code-I--431--g.copy-segmentation-fault-tf3952533.html#a11943808
Sent from the Grass - Dev mailing list archive at Nabble.com.
