[GRASS-dev] Re: [GRASSGUI] trying to compile wxPython digitizer display_driver
Michael Barton michael.barton at asu.edu
Sun Aug 19 23:11:32 EDT 2007
William,
Thanks for working on this. I just tried it. I seem to be missing something.
I put the display_driver folder into ../grass6/gui/wxpython as you
suggested.
I copied your new Makefile and setup.py into the display_driver folder
I then ran
python setup.py
I received the following error
cmb-MBP:~/grass_dev/grass6/gui/wxpython/display_driver cmbarton$ python
setup.pyusage: setup.py [global_opts] cmd1 [cmd1_opts] [cmd2 [cmd2_opts]
   or: setup.py --help [cmd1 cmd2 ...]
   or: setup.py --help-commands
   or: setup.py cmd --help
I tried --help-commands, which gave me some options. So I tried build,
build_py, and install as arguments to setup.py. The results are below. Any
suggestions?
Michael
======= attempts to run setup.py ==============
setup.py build
running build
running build_py
file grass6_wxdriver.py (for module grass6_wxdriver) not found
running build_ext
building 'grass6_wxdriver' extension
creating build
creating build/temp.macosx-10.3-fat-2.5
gcc -arch ppc -arch i386 -isysroot /Developer/SDKs/MacOSX10.4u.sdk
-fno-strict-aliasing -Wno-long-double -no-cpp-precomp -mno-fused-madd
-fno-common -dynamic -DNDEBUG -g -O3 -D__WXDEBUG__= -D__WXMAC__=
-D_FILE_OFFSET_BITS=64 -D_LARGE_FILES= -DNO_GCC_PRAGMA=
-I/usr/lib/wx/include/mac-unicode-debug-2.5 -I/usr/include/wx-2.5
-I/Library/Frameworks/GDAL.framework/unix/include
-I/Users/cmbarton/grass_dev/grass6/dist.i686-apple-darwin8.10.1/include
-I/Library/Frameworks/Python.framework/Versions/2.5/include/python2.5 -c
grass6_wxdriver_wrap.cxx -o
build/temp.macosx-10.3-fat-2.5/grass6_wxdriver_wrap.o
powerpc-apple-darwin8-gcc-4.0.1: grass6_wxdriver_wrap.cxx: No such file or
directory
powerpc-apple-darwin8-gcc-4.0.1: no input files
i686-apple-darwin8-gcc-4.0.1: grass6_wxdriver_wrap.cxx: No such file or
directory
i686-apple-darwin8-gcc-4.0.1: no input files
lipo: can't figure out the architecture type of: /var/tmp//ccFKl9UF.out
error: command 'gcc' failed with exit status 1
setup.py build_py
running build_py
setup.py install
running install
running build
running build_py
running build_ext
directory
powerpc-apple-darwin8-gcc-4.0.1: i686-apple-darwin8-gcc-4.0.1: no input
files
grass6_wxdriver_wrap.cxx: No such file or directory
lipo: can't figure out the architecture type of: /var/tmp//ccML6MOz.out
Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
