[GRASS-dev] Re: [GRASSGUI] Re: wxgrass won't work - how to set
updigitization?
Jerry Nelson
gnelson at uiuc.edu
Mon Aug 20 16:36:12 EDT 2007
Sounds like an item for a developer FAQ or maybe it should be a FMC
(frequently made comment) ;-)
Jerry
-----Original Message-----
From: grass-dev-bounces at grass.itc.it [mailto:grass-dev-bounces at grass.itc.it]
On Behalf Of Glynn Clements
Sent: Monday, August 20, 2007 3:30 PM
To: Moritz Lennert
Cc: Martin Landa; grass-gui; Michael Barton; GRASS developers list
Subject: Re: [GRASS-dev] Re: [GRASSGUI] Re: wxgrass won't work - how to set
updigitization?
Moritz Lennert wrote:
> > now fixed in SVN. The C++ driver is not finished yet.
> Does this mean we will have mission-critical elements (such as
> digitiation) in C++ ? In view of all the problems this has caused in the
> past, I would strongly plead against this.
For reasons which I've gone over more times that I care to remember, I
strongly suggest that anything which links against GRASS libraries
should be a separate program.
grass-dev mailing list
grass-dev at grass.itc.it
http://grass.itc.it/mailman/listinfo/grass-dev
