[GRASS-dev] random issues and bug
Thu Aug 23 03:17:26 EDT 2007
sorry this is a bit disorganized, but there are several issues.
But there is a common theme. :)
r.malcalc rand(a,b) for integer values of a,b
For a cellular automata seed I was trying to make a random 0/1 base map.
G63> r.mapcalc "rand.boolean = rand(0,1)"
G63> r.info -r rand.boolean
min=0
max=0
G63> r.mapcalc "rand.boolean = rand(0,2)"
min=0
max=1
I assume what is happening here is that the range for rand(0,2) is 0.0 to
1.999999 and the conversion to integer (CELL map) is done by a cast which
throws away the least significant bits. But to the casual user this seems
very counter intuitive.
r.mapcalc manual says:
    rand(a,b)               random value x : a < x < b
... but that's only true if a,b are floats. For integer values it is more
like: a <= x <= b-1
My first attempt was:
G63> r.mapcalc "rand.boolean = int( rand(0,1) + 0.5 )"
but that made an all 0s map as rand(n,n+1) == n as mentioned above.
(I didn't expect the cast to int)
In hindsight I can get that method to work by passing rand(,) two floats:
G63> r.mapcalc "rand.boolean = int( rand(0.0,1.0) + 0.5 )"
min=0
max=1
mmph.
Bug: r.mapcalc rand() not acting randomly.  (in at least 5.4 - 6.3cvs)
#simple_xy location
BOXSIZE=512
export GRASS_WIDTH=$BOXSIZE
export GRASS_HEIGHT=$BOXSIZE
d.mon x0
g.region n=$BOXSIZE s=0 w=0 e=$BOXSIZE res=1
r.mapcalc "rand.boolean = rand(0,2)"  # make a map of 0s and 1s
d.rast rand.boolean
screenshot:  (1:1 region rows/cols to image rows/cols)
  http://bambi.otago.ac.nz/hamish/grass/bugs/rmapcalc_rand_int_band_63cvs.png
vertical bands, the rows have a repeating pattern to them.
weird-- in GRASS 6.0.2 each row is one cell shorter and the pattern
drifts to the left (box is 1:1 so ends up in opp corner).
In 5.4.0 it's the same as both 6.3cvs and 6.2.2, ie vertical bands.
  http://bambi.otago.ac.nz/hamish/grass/bugs/rmapcalc_rand_int_band_602.png
  http://bambi.otago.ac.nz/hamish/grass/bugs/rmapcalc_rand_int_band_540.png
My first guess was that this arrived with the addition of $GRASS_RND_SEED
and the seed was reset to the same value at the start of each row when it
should really only be set once at the start of the module.
After short reflection that's not the case (it's not a smear) but there
certainly is a repeating pattern. Aliasing effect? Resizing the xmon
doesn't get rid of the pattern, it's in the cells. By setting the region
to be one bigger than 512x512 the effect goes away:
g.region n=$((1+ $BOXSIZE)) s=0 w=0 e=$((1 + $BOXSIZE)) res=1
eh? power of 2 issue?
r.surf.random
to back up a little, my first attempt to make the 0/1 map was with
r.random, but that requires a base map and is for placing points.
Wrong module.
Next I tried r.mapcalc and ran into above issues.
Next I tried r.surf.random. It creates a DCELL map with data in the range
of two integers.
One thing which struck me as odd is that r.surf.random creates a DCELL map
from two integer command line options. If you create a map with floating
points numbers, why not allow min and max to be any real number??
I've just now added an -i flag to r.surf.random to write out a CELL map.
I made that be in the range of [min <= x <= max] for int, and for DCELL
kept (min < x < max) [or whatever rand() gives]. As this doesn't match
r.mapcalc behaviour (see above) I think we need to change either one or
the other module for consistency's sake, then document the choice well.
My first attempt to add the -i flag was like:
 *(row_out_C + col_count) = (CELL) floor(rand1(2742)*(max-min)+min +0.5);
but that under-represents first and last bin.
e.g. for min=0 max=10 the 0 and 10 bins only have half the cells of 1-9.
G63> r.surf.random.MOD rsrand.i -i min=0 max=10
G63> d.histogram rsrand.i
G63> r.stats -c rsrand.i
 100%
0 13032
1 26190
2 26142
3 26262
4 26336
5 26250
6 26171
7 26513
8 26262
9 25999
10 12987
as the "1" bin draws from the range of 0.5-1.49999 and the 0 bin only
has half that space (0.0-0.49999) to draw from.
so I made the -i version as follows:
  *(row_out_C + col_count) = (CELL) (rand1(2742)*(max+1-min)+min);
but that goes back to the question of should min=0, max=10 create 11 bins
or 10? For the integer case, I'd say include the end numbers; but that
probably means changing r.mapcalc's rand(int,int) to be the same. ?????
As for Numerical Recipes code in the module (or not), it uses rand1()
from the gmath library.  lib/gmath/rand1.c
How to cite that in the r.surf.random.html help page? I put:
"It uses the random number generator drand48() or rand(), depending on
the user's platform."
but I'd much rather be specific and say those come from the GNU Project
or as defined in POSIX 1.1 or C99 std, or libc6 or whatnot, but don't
know the correct answer.
as for drand48, the man page says:
NOTES
   These functions are declared obsolete by SVID 3, which states
   that rand(3) should be used instead.
So should we remove the "#if defined(HAVE_DRAND48)" parts from
lib/gmath/rand1.c?
thanks,
Hamish
