[GRASS-dev] Re: [GRASSGUI] Re: wxgrass won't work - how to set up digitization?
Fri Aug 24 15:53:09 EDT 2007
Martin Landa wrote:
> > > > Does this mean we will have mission-critical elements (such as
> > > > digitiation) in C++ ?
> > > in C++ is written only minimalistic display driver (library) for
> > > digitization tool which draws vector elements on map canvas. This
> > > library is used only for rendering purposes (question of speed).
> > Do you mean the actual rendering, or retrieving the vector data to be
> > rendered?
> Sorry, I mean retrieving the vector data to be rendered...
That probably does need to be done in C.
You could use a slave process to do that part, but it would need to be
persistent; you can't spawn a new command for each operation.
If the Python code is loading a binary module which uses the GRASS
libraries, the digitiser needs to be a separate process from the rest
of wxgrass.
