[GRASS-dev] compile directions
Moskovitz, Bob Bob.Moskovitz at conservation.ca.gov
Fri Aug 24 18:07:49 EDT 2007
Would using ccache (http://ccache.samba.org/) be a good way to speed up compiles after a make distclean?  I'm thinking of using ccache but I would like to hear if anyone is using it while doing grass development.
-----Original Message-----
[mailto:grass-dev-bounces at grass.itc.it]On Behalf Of Glynn Clements
Sent: Friday, August 24, 2007 1:17 PM
To: Gerald Nelson
Cc: grass-dev at grass.itc.it
Subject: Re: [GRASS-dev] compile directions
Gerald Nelson wrote:
> There have been lots of emails recently about compiling issues, and
> one common thread is a question about whether you ran 'make distclean'
> first.
> Is there any reason NOT to always run make distclean?
For developers, repeatedly re-compiling from scratch would be a major
nuisance.
> Should it be part of the standard directions?
I think so.
It should always be done before "cvs update".
grass-dev mailing list
http://grass.itc.it/mailman/listinfo/grass-dev
